An URL parameter is not working properly in the grafana chart
    Grafana v10.3.3 ( 252761264e)
    Dynamic chart render
    By creating a URL parameter and load the data based on the param value
  • What happened?
    Its always showing chart data for first result of query variable result
    Wanted to render the chart based on the URL param value
    select memory from lab_server where server_id = ${serverId}
    NO
    Dashboard URL variables | Grafana documentation
