Grafana v8.0.6 (68fe9e3431) on RHEL8 and InfluxDB V2 -
I would like an alert to fire and be able to see the hosts in a table that it’s alerting about -
The following is my alert config.
from(bucket:v.bucket)
|> range(start:-1d)
|> filter(fn:(r) =>
r._measurement == “cpu” and
r.cpu == “cpu-total” and
r._field == “usage_idle”
|> aggregateWindow(every: 1m, fn: mean) -
What happened?
When it alerts it’s only shows that it’s alerting without much more info -
I would have expected a simple list of alerting devices -
I just use the flux query that I use for a graph
Thanks,
Nick L
