Alert List strange behavior
Version 4.6.1 running on Debian 9
With Current state I see 4 green hearts.
When I change to Recent state change I don’t see anything, but when I change Max items to 1 I see one green heart when i change to 10, I see nothing. If I change to 2 I see one green heart and one red after this I can change to almost any value but I will never see more than one green and one red.
I tried same Debian but with 4.6.0 beta 2 then it works correct.
That is very strange, I am unable to replicate it here:
http://play.grafana.org/dashboard/db/alerting-list-issue?orgId=1
Can you?
No, I cannot replicate it from the link.
I saw that you have 4.7.0, I will update my installation and try again.
About my installation: I installed 4.6.0, then 4.6.0 beta2 and then 4.6.1(with dpkg -i)
I had a clone from my instance(guest,running VirtualBox) which had “4.6.0 beta2” I upgraded it to 4.6.1 with dpkg and Alert List is working correct, like the link above.
On my active instance I have 4.6.1, I installed 4.6.1, again, over 4.6.1 but it have the same problem with Alert list. It is something with the installation on the active instance.
I will try other stuff and get back.
Thank you for your help so far.
I tried to uninstall Grafana but after I installed it again all my dashboards was still there and Alert List is still wrong. I deleted grafana.ini manually but still after this all my dashboards are still there and Alert List is not working
How can I do to really delete everything?
i tried:
apt-get remove grafana
apt-get remove --auto-remove grafana
apt-get purge grafana
apt-get purge --auto-remove grafana
all commands with su
After I took a new Debian and installed 4.6.1 alert list is ok.
What I noticed now in your link and my Alert List is that Max items doesn’t when you selected “Current state”
