Add cloudwatch logs to drill down
    • Grafana cloud
    • I’ve set up a cloudwatch data source and can query the logs just fine using the explore console. However, it’d be convenient if they were in the log drill down console with the rest of my logs.
    • Cloud watch isn’t in the data source drop down in the log drill down console. Can’t see a way to configure this in the data source settings.
Drill down feature is for Loki, not CloudWatch
So when you set up a cloud watch data source the logs aren’t ingested into loki, they’re queried directly?
no, when you have CloudWatch datasource then you are connecting and querying CloudWatch itself. Grafana doesn’t store any logs.
