Grafana Cloudwatch LogGroup
Hi There, I am using Grafana V6.7.3 and i am using AWS Cloudwatch as data source, i am trying to fetch the cloudwatch log group so that i can execute query and get the cloud watch logs but its not working at my end , please assist
  • What happened?
If it’s “not working” then there’s probably a “problem”.
Please give us more details of exactly what you are doing and what tells you
that it’s not working (eg: error messages, either on-screen or in log files),
and we might then be able to help you work out what the problem is.
Antony.
