An error occurred within the plugin - AWS CloudWatch Query
Grafana v10.1.1 (0cfa76b22d)
Enterprise edition (free)
I would like to run CloudWatch LogsInsights Query using Log Groups
trying to use the CloudWatch datasource and build the dashboards
  • What happened?
getting a http 500 error code.
“message”: “An error occurred within the plugin”,
“messageId”: “plugin.downstreamError”,
“statusCode”: 500,
“traceID”: “”
grafana logs show this error “level=error msg=“Internal server error” error=”[plugin.downstreamError] failed to query data: failed to execute log action with subtype: StartQuery: MalformedQueryException: Querying LogGroups by ARN is not supported. (Service: AWSLogs; Status Code: 400; Error Code: MalformedQueryException; Request ID: b00f4d59-8fd4-4774-8cef-2e6097568e65; Proxy: null)\n{\n RespMetadata: {\n StatusCode: 400,\n RequestID: "5d973edd-1a0e-4096-a31b-f6c981933046"\n },\n Message_: "Querying LogGroups by ARN is not supported. (Service: AWSLogs; Status Code: 400; Error Code: MalformedQueryException; Request ID: b00f4d59-8fd4-4774-8cef-2e6097568e65; Proxy: null)"\n}"
get the result for the CloudWatch Query
http 500 error in the UI (from the network tab)
    None
Issue was resolved!!!
