I’ve recently plugged my Grafana into my CloudWatch to aggregate all my logs and metrics into one place.
The connection went smoothly, but now I’m trying to find a way to explore my logs. I couldn’t find a way to go through them smoothly, and I’m not sure if it’s because of CloudWatch limits or that I’m not using the right tools.
For example, I have a keyword I want to search into my logs. This works fine with | filter @message like /keyword/. However, as soon as I start to get more context about the line, this gets complicated. How can I display lines before or after the line that matched my filter ? Is there a way to do it in Grafana ? I know there’s a way to do it in CloudWatch logs insight, event if it’s not super smooth.
Is it also possible to start log trailing within Grafana ?
Or am I asking for too complicated things and there’s just a limitation with how CloudWatch works ?
Thanks !
