6.0.2 with KairosDB -
Essentially, I would like to have context to the time series chart. So when a user selects a point on the chart, I would like to display a text value that will provide context to that point in time. e.g. I have numeric Temperatures and pressures displaying on the time series chart. The database also has a part number string captured. I’d like to visualize the part number string along with the Temperatures and Pressures at a given time. I am currently displaying the text values in a separate Table - Time series to rows, but ideally I would like the text values to be displayed on the time series chart so the user can easily determine the context. -
I was hoping to achieve this by adding annotations to the chart and add the value of the part number tag in the description. Is there is a better way to visualize context? -
What happened?
The annotation description displays the tag literally instead of retrieving its value -
The actual value of the tag is displayed in the description -
No Errors -
Just the Annotations online doc
