Filter Tag according to Annotation List
I use annotations to tag a number of data points on a time series chart. but I can’t find a way to display detailed data based on the tag that I have selected.
is there any solution for this?
Hi @
taniaciu21,
Thanks for opening this post.
Please review the submission template and include more details:
  • What is your datasource?
  • What visualization panel you are using e.g. time-series, bar chart, histogram etc?
  • What happened?
