Adding annotations 'programmatically'
Hi everyone !
I want to add annotation to my graph and I saw that I can use templating for that. But I have to add a lot of annotation and continuously. So I want to know if there is a way to add it with a query, like that I can feed a table with my annotation on my database and grafana will take it automatically. I don’t want to hold Ctrl + click on the graph to add the hundred annotations I have on a regular basis.
I used the following query :
SELECT
  Datum as time,
  Tyype as text,
  taag as tags
FROM
  panne3
WHERE
  $__timeFilter(Datum)
with my table panne3 (id int, Datum date, tyype text, taag text)
but it gives my the error : Value column must have numeric datatype, column: tags type: string value: Type 2.
How I can set tags as numerical values, it must be text ?
Thanks a lot for your answer !
No matter, I found…
What was it you “found”?
