I have the problem that I receive following errormessage during activating https on grafana docker:
Error: ✗ *api.HTTPServer run error: failed to open listener on address grafana.testnet.net:3000: listen tcp 192.51.96.105:3000: bind: cannot assign requested address
192.51.96.105 is an address allocated by JNIC in Japan
I recommend you use genuinely internal-only domain names and RFC1918 addresses
unless you really are working on a public-Internet server, in which case you
need IP address and hostname to match up.
