Access to play.grafana.com
Hi
Is it possible to gain access to provide a dashboard on play.grafana.com.
I would like to use this as a reference when reporting issues.
Thanks
E
@allomorphy if it’s just one dashboard you want to create, you can also send me the dashboard JSON and I can create it there and give you a link to ref on your issue
That is such a kind offer @davidallen5
I will DM you to send the json
:pray:
