3 Queries for 1 Bar Gauge
Hi there!, i’m trying to generate 1 Bar Gauge panel with 3 differents queries. these queries gives me information about “Blocked”, “Failed” and “Passed” Test Cases (from a TestLink DB) but these queries is just shown in Green.
How can i diference between gauges in colors (First in blue, second in Red and the other in green).
Thanks in advance.
Not sure I understand what you’re asking. Do you want one bar gauge where the queries are combined, where the different queries are represented in different colors?
Thanks for your reply!.
that image is the result of a single query, so what I did was repeat the query 3 times filtering by result to be able to change the colors separately
