2h of data (on the left) gets cutoff
Hi everyone,
I am just trying out Grafana right now and on every line graph I make the first two hours are missing:
The Data gets loaded, the generated SQL works and in the Query Inspector I can see the missing Data:
While writting this the behavior changed a little (or whats more likely, I just overlooked something…).
It generates the right SQL Query with the right timestamps, but I do not get the right Data back:
The first data row has the unix time 1594404025000 which converts to 10.7.2020, 20:00:25. Thats the first Datapoint shown in the graph.
When I execute the SQL query in heidisql I get the data which it should select:
[As I am a new user I can’t upload more than two images in one post. See first reply)
HeidiSQL and Grafana are running on the same PC (Win10), the mysql db is running on an external server(WinServer2019 I think). Both machines have the same time.
I ve already read through these two posts:
Does not seem to be the same issue:
Maybe something in that direction, but the time is the same on the server and my PC (both are synced over the internet)
Maybe I am just overseeing something obvious…
Does someone know how to fix that?
Screenshot of heidisql with the correct Data (Same SQL query as Grafana uses):
This looks time zone related. It’s two hours off and you seem to be located in Germany (which would be UTC+2).
Starting with the simple stuff:
  • What version of Grafana are you on? (Looks like 7.0?)
  • What are your time zone settings for the dashboard (in dashboard settings):
  • What type does your Datum column have? Timestamp or datetime?
Yep, I am in the same timezone as Germany (I am from Austria).
  • I am on Grafana v7.0.5 (efbcbb838b), just installed it a few days ago.
  • My Timezone was set to Default, changing it to Vienna did not change anything. (Changing it to London UTC+0 did not change anything)
  • datetime
When testing with heidiSQL I just copied the SQL query directly from the query inspector and with that there should not be any problems with timezones? because unix time is unix time isn’t it?
I ve just tried to move the data from the original mysql 8.0.2 DB to an 10.1.38-MariaDB.
Using my MariaDB, which ist installed on the same PC as Grafana, does not solve the problem.
Any ideas where the problem might be?
Try it:
select unix_timestamp(Datum) as "time"
Hi, I had the same issue. In my case it seems that the _timefilter-Makro does not reflect the local timezone. See this post:
I ve tried both solutions, and both worked!
Original SQL Code:
SELECT Datum AS “time” FROM …
First solution:
SELECT unix_timestamp(Datum) AS “time” FROM …
Second solution:
SELECT convert_TZ( Datum ,@@SESSION.time_zone,‘+00:00’) AS “time” FROM …
Thanks for the help and the working exmaples! @sancho1234 and @bmerz
