12.4.0
- What are you trying to achieve?
Trying to import a dashboard that references library panels like this one: EVCC: Today | Grafana Labs
- How are you trying to achieve it?
Tried the following methods:
- Import dashboard through Grafana.com
- Upload dashboard from file system
- Export dashboard from a migrated 12.4.0 system and import again using Classic or V1 resource.
Neither of these methods works. What worked was:
Export as V2 resource - which however eliminates all library panel and I end up with the message “The Dynamic Dashboard feature is temporarily disabled”. See New warning about dynamic dashboards being unavailable
What happened?
After import all library panels are broken:
Message look like this:
However library panels can be seen in the list.
Proper import of dashboard with library panels like it did work with Grafana 12.3.x and earlier
- Can you copy/paste the configuration(s) that you are having problems with?
Yes. Just try to import this dashboard: EVCC: Today | Grafana Labs
