Hi folks,
I’ve been tring for a while not to get a zero-centered gauge but cannot find one.
Use-Case:
I have solar panels on my roof and use Grafana to show the generation v. house-usage v. grid-usage.
Like such:
I am trying to combind all those, or at least a new one, where it shows a zero-centered gauge where it shows the net usage (getting the data to show -100-0-100 is not a problem)
Is there a way I can coax the gauge panel to do this?
In the example below I would like the vertical to show zero and the green bar would start there, arc left to 50. Not start at -100 and head right to 50.
Now, if I could colour that too ![]()
Happy to try ideas and, if needed, write own code / plugin if I can get some guidence.
TIA!
Crispin
