Zabbix plugin installs fine but nothing happens when I try to open the grafana homepage. Below is the httpd trace. (changed the IP addr).
What is that I am doing wrong?
[Tue Apr 14 19:15:21.083975 2020] [authz_core:debug] [pid 31162] mod_authz_core.c(809): [client 1.2.3.4:37584] AH01626: authorization result of Require all granted: granted
[Tue Apr 14 19:15:21.084021 2020] [authz_core:debug] [pid 31162] mod_authz_core.c(809): [client 1.2.3.4:37584] AH01626: authorization result of : granted
[Tue Apr 14 19:15:21.084129 2020] [proxy:debug] [pid 31162] mod_proxy.c(1123): [client 1.2.3.4:37584] AH01143: Running scheme unix handler (attempt 0)
[Tue Apr 14 19:15:21.084157 2020] [proxy_ajp:debug] [pid 31162] mod_proxy_ajp.c(722): [client 1.2.3.4:37584] AH00894: declining URL fcgi://localhost/usr/share/zabbix/api_jsonrpc.php
[Tue Apr 14 19:15:21.084175 2020] [proxy_fcgi:debug] [pid 31162] mod_proxy_fcgi.c(972): [client 1.2.3.4:37584] AH01076: url: fcgi://localhost/usr/share/zabbix/api_jsonrpc.php proxyname: (null) proxyport: 0
[Tue Apr 14 19:15:21.084191 2020] [proxy_fcgi:debug] [pid 31162] mod_proxy_fcgi.c(979): [client 1.2.3.4:37584] AH01078: serving URL fcgi://localhost/usr/share/zabbix/api_jsonrpc.php
[Tue Apr 14 19:15:21.084203 2020] [proxy:debug] [pid 31162] proxy_util.c(2203): AH00942: FCGI: has acquired connection for ()
[Tue Apr 14 19:15:21.084219 2020] [proxy:debug] [pid 31162] proxy_util.c(2256): [client 1.2.3.4:37584] AH00944: connecting fcgi://localhost/usr/share/zabbix/api_jsonrpc.php to localhost:8000
[Tue Apr 14 19:15:21.084237 2020] [proxy:debug] [pid 31162] proxy_util.c(2293): [client 1.2.3.4:37584] AH02545: fcgi: has determined UDS as /var/opt/rh/rh-php72/run/php-fpm/zabbix.sock
[Tue Apr 14 19:15:21.084440 2020] [proxy:debug] [pid 31162] proxy_util.c(2426): [client 1.2.3.4:37584] AH00947: connected /usr/share/zabbix/api_jsonrpc.php to httpd-UDS:0
[Tue Apr 14 19:15:21.084697 2020] [proxy:debug] [pid 31162] proxy_util.c(2704): AH02823: FCGI: connection established with Unix domain socket /var/opt/rh/rh-php72/run/php-fpm/zabbix.sock ()
[Tue Apr 14 19:15:21.090987 2020] [proxy:debug] [pid 31162] proxy_util.c(2218): AH00943: FCGI: has released connection for (*)
