Hi All,
I recently enabled https for Zabbix and I updated my datasource in Grafana to use HTTPS url. I also had to enable “CA Cert” and upload the cert used for zabbix under “TLS/SSL Auth Details” for the datasource test to pass. Screenshot below.
I wanted to know which config file (may be grafana.ini) holds this updated info or what are the lines in the config file I need to add to incorporate these changes in command line instead of using GUI.
