Have anyone experienced any problem with “alexanderzobnin-zabbix-app” plugin at datasource creation when using https protocol in grafana?
Thanks,
Paulo José Miguens
Thanks,
Paulo José Miguens
What error are you getting?
HI Daniel,
When I try creating a datasource of type zabbix it gets a error but it happens only when the ssl is enabled in the grafana.ini
The error is connection error
Is it a self-signed certificate? And is the Zabbix connection also https?
Yes, it is a self-signed certificate, in the grafana. And only http is enabled in the zabbix.
Both services are installed in the same server and running on the same ip address.
