Y-axis slider: is it possible?
  • I’m using grafana Grafana v10.4.19 (5e7a8b1652)
  • I’m trying to build a Y-Axis slider.
    We have more than 10 trends on a single time-series panel, as shown above. We also have more than 10 different signals with very different ranges, which makes it difficult to define one fixed range for all of them..
  • To solve this issue, I expected to build a zoom slider on the Y-axis, but I don’t know if that’s possible.
Can someone help me?
As of Grafana 10.2 you can hold shift while clicking and dragging to zoom into a selected region on the y-axis
