Xy graph multiple automatic series
I am using the BigQuery connector to try and create an x y graph with days since release as the x and number of events as the x
I want each of the possible sources (source colum) to be there own series
I tried with the “Partition by values” transform and it works but i need to set up each series manually. The sources can change so it not ideal to have to keep updating
Is there a way to have a series per source automatically?
My sql is below:
    SELECT
      source,
      days_since_release,
      num_events
   FROM
  `table`
ORDER BY
  days_since_release
Welcome to forum @hello1ae5
Try
SELECT
      source as metric,
      days_since_release as [time],
      num_events as value
   FROM
  `table`
ORDER BY
  days_since_release
And make sure the Format is time series and not table
i get a query syntax error with [time], is this still on the xy graph type?
days_since_release is just a number not a date
Do you want a time series graph?
Which column is date time
No i dont have a datetime field, which is why i thought the xy chart was the best choice
duh apologies, you need to pivot your data either like this
SELECT days_since_release,
      [Vader III], [Sith V]
   FROM (
    select 'Vader III' as source,
    34 days_since_release,
    232 num_events
    union
    32 days_since_release,
    123 num_events
  union
    232 num_events
    union
    30 days_since_release,
    100 num_events
    union
    select 'Sith V' as source,
    3 days_since_release,
    22 num_events
    ) AS SourceTable
PIVOT
  MAX(num_events)
  FOR [source] IN ([Vader III], [Sith V],)
) AS PivotTable;
As you can see below the plugin wigs out and puts a metric as an Y value, which is incorrect.
or use apache echart multi line xy chart
