How do you wrap long lines of text in Grafana’s table? I’m using Grafana 10. I have seen many topic discussions on this questions but no real answer. I cannot use the older table. Any ideas? If this feature is not implemented, when will it be implemented?
you can turn on the cell value inspect to help you out:
it is not the wrapping you requested, but this gives a little eye when you hover over the data, and when you click the eye, you see the full text.
