Word cloud and grafana [loki datasource]
Good afternoon people!
I need direction. I need to create a panel in grafana using Word Cloud. I currently use Loki as a dataSource.
I didn’t find any examples and I don’t even know if it’s supported. Has anyone ever needed to use wordCloud with grafana and loki?
If so… can you give me a reference on how I save this data and what I need to do to appear on the panel?
Thank you very much in advance for your help.
There is a community plugin for Word Cloud, which I have never used
We recently added Word Cloud extension to the Apache ECharts Panel:
Many thanks for the reply.
I installed the plugin… volkovlabs.
Do you have a json of what a word cloud would look like?
I’m reading labels from json, can I use them with this framework?
Not available in Volkov Labs
If you have a printout of what the configuration would look like in grafana, that would also help… As I have never worked with this plugin… I’m a little lost
@douglasadriani I fixed the dashboard to allow Edit to Viewers. Thank you for reporting.
Here is the code we used. It has static values. For Data Source, please check out the documentation and YouTube tutorials
var option = {
  tooltip: {},
  series: [{
    type: 'wordCloud',
    gridSize: 2,
    sizeRange: [12, 50],
    rotationRange: [-90, 90],
    shape: 'pentagon',
    width: 600,
    height: 400,
    drawOutOfBound: true,
    textStyle: {
      color: function () {
        return 'rgb(' + [
          Math.round(Math.random() * 160),
        ].join(',') + ')';
    emphasis: {
      textStyle: {
        shadowBlur: 10,
        shadowColor: '#333'
    data: [
        name: 'Sam S Club',
        value: 10000,
        textStyle: {
          color: 'black'
        emphasis: {
          textStyle: {
            color: 'red'
        value: 6181
        name: 'Amy Schumer',
        value: 4386
        value: 4055
        name: 'Charter Communications',
        value: 2467
        name: 'Chick Fil A',
        value: 2244
        name: 'Planet Fitness',
        value: 1898
        name: 'Pitch Perfect',
        value: 1484
        value: 1112
        value: 965
        value: 847
        value: 582
        name: 'Lewis Hamilton',
        value: 555
        value: 550
        name: 'Mary Ellen Mark',
        value: 462
        name: 'Farrah Abraham',
        value: 366
        value: 360
        name: 'Serena Williams',
        value: 282
        name: 'NCAA baseball tournament',
        value: 273
        value: 265
return option;
