Windows _ logs are missing at the start of each hour
We have installed Grafana Alloy v1.14.0-rc.1 as a Windows service using alloy-installer-windows-amd64. We are experiencing an issue with hourly log rotation where logs generated at the start of each hour are missing.
We have tested multiple configurations, including different sync_period values, as well as running without sync_period. However, in all cases, logs at the beginning of each hourly rotation are being lost.
Has anyone encountered this issue before? Could you please help us identify the root cause and recommend a fix or workaround? Thank you.
option1
local.file_match “a_log_source” {
path_targets = [
{“path” = "D:\temp\aa\*.log ]
sync_period = “1ms”
loki.source.file “a_logs_k” {
targets = local.file_match.a_log_source.targets
tail_from_end = true
forward_to = [loki.process.a_process.receiver]
file_watch {
min_poll_frequency = “1ms”
max_poll_frequency = “250ms”
thank for info.But our case log rotation is happening every 1hr.
Hi All, more help if any one can to provide information on this
It looks like you’ve bumped into this: Alloy - not scraping logs after log rotation in Windows · Issue #2292 · grafana/alloy · GitHub Comment on the issue to help it gain attention/traction.
A workaround… give each rotated file a unique name (example, add a timestamp in the filename) instead of rotating on a fixed filename. This forces local.file_match to see a genuinely new path and start a fresh tailer.
“path” = "D:\temp\aa\*.log " logs rotation is happening every hour and log files are storing uniq files only . format :D:\temp\aa\Log.YYYY-MM-DD.hh.log
D:\temp\aa\Log.2026-08-25.12.log
D:\temp\aa\Log.2026-08-25.11.log
D:\temp\aa\Log.2026-08-25.10.log
D:\temp\aa\Log.2026-08-25.09.log
