Grafana Alloy - Reading line routine
I am having a problem where in my local system - the alloy configuration is working fine, but not in my server.
Issue - in my server, even though no new .gz log file is created, msg=“read lines routine: started” keeps happening for the sync_period that I have given.
Within my local system, msg=“read lines routine: started” happens only if a new .gz file gets created in the directory specified.
Could anyone please look into my issue, I really appreciate your efforts.
My alloy service
alloy:
    image: grafana/alloy:latest
    container_name: alloy
    restart: always
    volumes:
      - ./config.alloy:/etc/alloy/config.alloy
      - /home/abhishek/Documents/logs:/var/log/app-logs:ro  #the host directory is set to proper within my server...
    command:
      - run
      - --server.http.listen-addr=0.0.0.0:8083
      - /etc/alloy/config.alloy
    depends_on:
      - loki
    networks:
      - grafana-network
config.alloy file
local.file_match "log_files" {
  path_targets = [{"__path__" = "/var/log/app-logs/*/*.log"}]
  ignore_older_than = "24h"
  sync_period = "10s"
local.file_match "log_gz_files" {
  path_targets = [{"__path__" = "/var/log/app-logs/*/*.log.gz"}]
  sync_period = "30s"
loki.source.file "file_source" {
  targets = local.file_match.log_files.targets
  tail_from_end = true
  file_watch {
    min_poll_frequency = "1s"
    max_poll_frequency = "30s"
  forward_to = [loki.process.log_processing.receiver]
loki.source.file "file_gz_source" {
  targets = local.file_match.log_gz_files.targets
  file_watch {
    min_poll_frequency = "10s"
    max_poll_frequency = "1m"
  decompression {
    enabled = true
    initial_delay = "30s"
    format = "gz"
loki.process "log_processing" {
  stage.regex {
    expression = "/var/log/app-logs/(?P<service>[^/]+)/.*"
    source = "filename"
  stage.labels {
    values = { "service_name" = "service" }
  stage.timestamp {
    source = "timestamp"
    format = "RFC3339"
    action_on_failure = "skip"
  forward_to = [loki.write.loki_receiver.receiver]
loki.write "loki_receiver" {
  endpoint {
    url = "http://loki:8082/loki/api/v1/push"
Have you actually observed an issue other than the logs? Is it actually sending more logs than it should?
Thanks for your reply..
Actually, I found the issue, it was related to user permissions on the directory and files.
Both belong to different users. And also, I just rebuild my Alloy image. Maybe this was one which resolved the issue..
You can close this.
