I’m a brand new user and I set up Grafana on my first server yesterday. Today, I noticed that the disks and filesystems data in the dashboard is blank.
I used the boilerplate configuration on the setup (pasted below). I’m pretty sure all of the other metrics are showing, just these seem to be missing.
prometheus.exporter.self "alloy_check" { }
discovery.relabel "alloy_check" {
targets = prometheus.exporter.self.alloy_check.targets
rule {
target_label = "instance"
replacement = constants.hostname
rule {
target_label = "alloy_hostname"
rule {
target_label = "job"
replacement = "integrations/alloy-check"
prometheus.scrape "alloy_check" {
targets = discovery.relabel.alloy_check.output
forward_to = [prometheus.relabel.alloy_check.receiver]
scrape_interval = "60s"
prometheus.relabel "alloy_check" {
rule {
source_labels = ["__name__"]
regex = "(prometheus_target_sync_length_seconds_sum|prometheus_target_scrapes_.*|prometheus_target_interval.*|prometheus_sd_discovered_targets|alloy_build.*|prometheus_remote_write_wal_samples_appended_total|process_start_time_seconds)"
action = "keep"
prometheus.remote_write "metrics_service" {
endpoint {
url = "https://prometheus-prod-13-prod-us-east-0.grafana.net/api/prom/push"
basic_auth {
username = "1839229"
password = "glc_eyJvIjoiMTI0MzkxOCIsIm4iOiJzdGFjay0xMDYxMTIwLWludGVncmF0aW9uLXByb2QyIiwiayI6IlVwWTY4TDA2NDVTOHRROENGNDhrRlBZeiIsIm0iOnsiciI6InByb2QtdXMtZWFzdC0wIn19"
loki.write "grafana_cloud_loki" {
endpoint {
url = "https://logs-prod-006.grafana.net/loki/api/v1/push"
basic_auth {
username = "1018900"
prometheus.exporter.windows "integrations_windows_exporter" {
enabled_collectors = ["cpu", "cs", "logical_disk", "net", "os", "service", "system", "time", "diskdrive"]
discovery.relabel "integrations_windows_exporter" {
targets = prometheus.exporter.windows.integrations_windows_exporter.targets
rule {
replacement = "integrations/windows_exporter"
rule {
prometheus.scrape "integrations_windows_exporter" {
targets = discovery.relabel.integrations_windows_exporter.output
forward_to = [prometheus.relabel.integrations_windows_exporter.receiver]
job_name = "integrations/windows_exporter"
prometheus.relabel "integrations_windows_exporter" {
rule {
source_labels = ["volume"]
regex = "HarddiskVolume.*"
action = "drop"
rule {
action = "keep"
regex = "up|windows_cpu_interrupts_total|windows_cpu_time_total|windows_cs_hostname|windows_cs_logical_processors|windows_cs_physical_memory_bytes|windows_disk_drive_status|windows_logical_disk_avg_read_requests_queued|windows_logical_disk_avg_write_requests_queued|windows_logical_disk_free_bytes|windows_logical_disk_idle_seconds_total|windows_logical_disk_read_bytes_total|windows_logical_disk_read_seconds_total|windows_logical_disk_reads_total|windows_logical_disk_size_bytes|windows_logical_disk_write_bytes_total|windows_logical_disk_write_seconds_total|windows_logical_disk_writes_total|windows_net_bytes_received_total|windows_net_bytes_sent_total|windows_net_packets_outbound_discarded_total|windows_net_packets_outbound_errors_total|windows_net_packets_received_discarded_total|windows_net_packets_received_errors_total|windows_net_packets_received_unknown_total|windows_os_info|windows_os_paging_limit_bytes|windows_os_physical_memory_free_bytes|windows_os_timezone|windows_service_status|windows_system_context_switches_total|windows_system_processor_queue_length|windows_system_system_up_time|windows_time_computed_time_offset_seconds|windows_time_ntp_round_trip_delay_seconds"
loki.process "logs_integrations_windows_exporter_application" {
forward_to = [loki.write.grafana_cloud_loki.receiver]
stage.json {
expressions = {
level = "levelText",
source = "source",
stage.labels {
values = {
level = "",
source = "",
loki.relabel "logs_integrations_windows_exporter_application" {
forward_to = [loki.process.logs_integrations_windows_exporter_application.receiver]
rule {
source_labels = ["computer"]
target_label = "agent_hostname"
loki.source.windowsevent "logs_integrations_windows_exporter_application" {
locale = 1033
eventlog_name = "Application"
bookmark_path = "./bookmarks-app.xml"
poll_interval = "0s"
use_incoming_timestamp = true
forward_to = [loki.relabel.logs_integrations_windows_exporter_application.receiver]
labels = {
instance = constants.hostname,
job = "integrations/windows_exporter",
loki.process "logs_integrations_windows_exporter_system" {
stage.json {
expressions = {
source = "source",
stage.labels {
values = {
level = "",
source = "",
loki.relabel "logs_integrations_windows_exporter_system" {
forward_to = [loki.process.logs_integrations_windows_exporter_system.receiver]
rule {
loki.source.windowsevent "logs_integrations_windows_exporter_system" {
locale = 1033
eventlog_name = "System"
bookmark_path = "./bookmarks-sys.xml"
forward_to = [loki.relabel.logs_integrations_windows_exporter_system.receiver]
labels = {
