Why status history panel overlaps itself
    Grafana v8.5.1, Windows 10
    I want to have a status history like on official site - Status history | Grafana documentation
    I query data from azure monitor using KQL. I group my data into bins of 30 minutes and take latest within each bin. Then I pivot data to make it look like this.
  • What happened?
    Columns overlap each other like this:
    I expect my columns to take as much as they can without overlapping. I assumed I needed ‘column width = 1’ to achieve that but it seems not. I want columns to leave space for others if there could be other tiles.
    Here columns are respectful to time even if there is no data in between. Basically I want my top screenshot to like the one below. In it I manually changed column width but I need this to be automatic.
    I am not sure what it is, I can copy Json
  "id": 2,
  "gridPos": {
    "h": 8,
    "w": 12,
    "x": 0,
    "y": 0
  "type": "status-history",
  "title": "stat history",
  "datasource": {
    "type": "grafana-azure-monitor-datasource",
    "uid": "abcdef"
  "fieldConfig": {
    "defaults": {
      "custom": {
        "lineWidth": 1,
        "fillOpacity": 70
      "color": {
        "mode": "thresholds"
      "mappings": [
          "options": {
            "0": {
              "color": "green",
              "index": 0,
              "text": "OK"
            "1": {
              "color": "red",
              "index": 1,
              "text": "KO"
            "2": {
              "color": "orange",
              "index": 2,
              "text": "WARN"
          "type": "value"
      "thresholds": {
        "mode": "absolute",
        "steps": [
            "color": "green",
            "value": null
    "overrides": []
  "options": {
    "showValue": "auto",
    "rowHeight": 0.9,
    "colWidth": 1,
    "legend": {
      "displayMode": "hidden",
      "placement": "bottom"
    "tooltip": {
      "mode": "single",
      "sort": "none"
  "targets": [
      "azureLogAnalytics": {
        "query": "",
        "resource": "/subscriptions/foo/resourceGroups/bar/providers/microsoft.insights/components/pass",
        "resultFormat": "time_series"
      "azureMonitor": {
        "dimensionFilters": [],
        "timeGrain": "auto"
      "datasource": {
        "uid": "abcdef"
      "queryType": "Azure Log Analytics",
      "refId": "A",
      "subscription": "123456789"
    No
    No
I face exactly the same problem:
The column width I set to 0.4 and even it overlapps. What I see is that it seems to be dependent from the data somehow. The above image is taken with a timerange of now-14d.
The following is taken with a timerange of now-13d:
This is really annoying - we need help to get rid of this bug.
Thanks for any help
Hi, this issue is still alive and we get no help here for about one month :-(.
Can someone (from grafana team) please help in this regard?
Thanks!
Hi, this issue is (again) still alive and we get no help here for about three month :-(.
Thanks!
