Hey, i am trying to show the status history from my park sensors. But the problem is, the results are overlapping when i want to show the results from last 24 hours The box, which is there to show the value if it is ‘true’ or ‘false’, is also thin and long
- There is no problem when i show the last results from 1 Hours.
But when i want to show the last results from 24 Hours then they are overlapping also becoming thin and long.
True text is too small to read. Whereas in the Status History documentation, the boxes are big enough, is there a way to set this? (The example of Status History documentation from Grafana)
- I want make them a small box, which i can read the result clearly for the last 12 Hours not only 1 hours.
And also i want to see the last last valid information always until i get the new information from my sensor. Is there any way to make it?
Thank you in advance for your help.
