Status History Date only format
Can some one please tell me if i am doing something wrong or if the software just doesn’t work the way i would like it to.
    I am currently using version 10.0.3 on a ubuntu 20.04 VM
    I am trying to format the _time value from a influxDB data source in a Status History panel
    I’ve tried using a override to change the MM/DD HH:MM formatting that is uses by default to just a MM/DD format
  • What happened?
    Nothing seems to happen when i apply this to the panel object.
    However if i change the object from status history panel to a table. The override looks to work as expected.
  • Did you receive any errors in the Grafana UI or in related logs? No error message, it seems to do nothing.
  • Did you follow any online instructions? no
Any help on this would be great, or if there is another way to get the same visual output that would be acceptable as well.
Any luck on that?
