Grafana v12.3.1 (3a1c80ca7c) -
To have grouped alerts by message and service name and get just one email message bymessagelabel and one more message ifservice_namelabel is different too. -
I tried to deleteservice_name, but grouping bymessagedoesn’t appeared. -
What happened?
I see in web interface child policies:
But I get all messages by evaluation period in one message. -
What you expected to see?
Grouped separate messages. And also I voted for this topic, because I can’t edit policies from web interface and it is hard to debug problems like this. -
policies: - receiver: grafana-default-email group_by: - grafana_folder - alertname group_wait: 30s group_interval: 5m repeat_interval: 4h routes: - receiver: grafana-default-email object_matchers: - ["message", "=~", ".+"] group_by: ["service_name", "message"] mute_time_intervals: - no_night -
No -
I see that routes syntax is the same as parent Use configuration files to provision alerting resources | Grafana documentation
Hi @mihalt,
What does message refer to in this context? Is message a label that you’ve defined in the alert rule settings?
Here are some relevant docs for alert grouping:
- Label types explains the different kinds of labels available on alerts
- Notification grouping describes how grouping works and how to configure it in notification policies
Also, how are you provisioning your notification policies? If you’re running into issues, one practical approach is to first configure the policy in Grafana until it works as expected, and then export that configuration for provisioning.
Copy past your configuration now see any error in grafana ui , also give grafana log after restart the grafana .
logger=context userId=0 orgId=0 uname= t=2026-02-12T15:56:49.9827197+05:30 level=info msg=“Request Completed” method=GET path=/ status=302 remote_addr=[::1] time_ms=0 duration=0s size=29 referer= handler=/ status_source=server
logger=context userId=0 orgId=0 uname= t=2026-02-12T15:56:53.2778908+05:30 level=info msg=“Request Completed” method=GET path=/api/plugins/grafana-pathfinder-app/settings status=401 remote_addr=[::1] time_ms=0 duration=0s size=102 referer=http://localhost:3000/login handler=/api/plugins/:pluginId/settings status_source=server errorReason=Unauthorized errorMessageID=auth.unauthorized error=“cannot authenticate request”
logger=infra.usagestats t=2026-02-12T15:56:54.8890419+05:30 level=info msg=“Usage stats are ready to report”
logger=context userId=1 orgId=1 uname=admin t=2026-02-12T15:57:02.7952508+05:30 level=info msg=“Request Completed” method=GET path=/api/live/ws status=-1 remote_addr=[::1] time_ms=3 duration=3.6062ms size=0 referer= handler=/api/live/ws status_source=server
logger=ngalert.notifier component=alertmanager orgID=1 t=2026-02-12T15:57:06.9134582+05:30 level=info msg=“Applying new configuration to Alertmanager” configHash=8fa38196a969a59b2c835928d3efd139
logger=context userId=1 orgId=1 uname=admin t=2026-02-12T15:57:07.8548641+05:30 level=info msg=“Request Completed” method=GET path=/api/plugins/grafana-oncall-app/settings status=404 remote_addr=[::1] time_ms=19 duration=19.0215ms size=64 referer=http://localhost:3000/alerting/routes handler=/api/plugins/:pluginId/settings status_source=server
I did it in regex named capturing group in the alert_rules.yaml like:
apiVersion: 1
groups:
- orgId: 1
folder: Custom
interval: 5m
rules:
- title: Error in apps
condition: B
data:
- refId: LOGS
queryType: range
relativeTimeRange:
to: 0
model:
datasource:
type: loki
editorMode: code
expr: "count_over_time({service_name=~\"(?P<message>.*)`\r\n[60m])"
I provision everything.
Export of Notification configuration
apiVersion: 1
contactPoints:
- orgId: 1
receivers:
- uid: grafana-default-email
type: email
settings:
addresses: myemail@gmail.com
message: '{{ template "custom_email.message" .}}'
singleEmail: false
subject: '{{ template "custom_email.subject" .}}'
disableResolveMessage: false
