9.2.20 -
Create a new template to use for webhook alerts. -
In creating a new contact point add the go template file. -
What happened?
Looking for default template grafana uses when sending a webhook alert. -
Ideally locate the file in github that I can use as a base of customization. -
N/A -
N/A -
Tried to follow this doc, but it appears the webhook is different from the templates shown.
Create notification templates | Grafana documentation
Found the answer – in case anyone else is looking:
It can be found in file alerting/templates/default_template.go
within source code of Grafana. You can view it on GitHub here.
