What is the correct to show multiple values in a Panel
I am new to Grafana & i am using a Stat Panel to show multiple values. When i change the color mode to background then it appears like different tiles for each value
  1. Is there any way to change the color of the entire panel without showing the split lines in
    between?
  2. Can you suggest me any other control which can show the data as a single dashboard.
Any kind of help is highly appreciated.
Thanks!
AFAIK it’s not possible to disable the padding between each tile. If this is something you’d like to see, maybe submit an enhancement request?
Marcusolsson thanks for the response, yes i will submit a request.
Can you please let me know if its possible to create this dashboard using any other panel or plugin.
Thanks.
If the only thing you want to change is the padding, then no. Maybe there’s a browser extension that lets you change the CSS?
Yes, please let me know the name of the browser extension.
Thanks!
Try using boom theme plugin to customize the css on any dashboard.
You can use single stat panel with repeater option.
