Hello mates,
I’m new to Grafana and I have a question.
The version I use is v9.4.7
I used the table in one of my dashboards. I have a display named day, we got the dates from the last 7 days but there’re two that are missing. For example we got the 26.05; 27.05; 30.05; … but I miss the 28 and 29. What can I do to get these? Or is it because we don’t have any datas at these days?
If InfluxDB does not have any data on the 28th, 29th, etc. then Grafana will not have data to put into the table.
What about changing to a time series graph? (you can also change it to bars if that’s your preference) How does the data look spanning the 24th through the 31st?
Yes thats what I thought. I had to do it with a Table cause my superior told me but Thank You for the answer.
By that do you eventually know how I change the time e.g. in time series to months? If that works? Or is there an other visualization where I can do that?
Cause I want to have a view over the consumption per month.
