Ways of displaying day of the week on time series
I’d like to be able to visualize the day of the week in a time series chart. It doesn’t look like there’s a way to include day of the week on the x-axis?
Alternatively, is it possible to have day of the week as part of the tool tip when mousing over a point?
Or maybe if “Time Regions” allows for custom text for that region - and the custom text would disappear if it can’t be displayed?
Here’s me trying to show what I’m thinking of.
I just want a better way to make days of the week more visible in visualizations. Maybe there’s a better way that Grafana does this?
I’m using Grafana 7.1.5.
it looks like you might want to use the Bar Chart, which can use arbitrary strings on the x axis:
https://play.grafana.org/d/ktMs4D6Mk/5-bar-charts-and-pie-charts?orgId=1
See the docs for the data model that you will need to fit:
NOTE: you’ll have to update to use the bar chart
This may be a bit late, but if you are using Prometheus, defining this Prometheus query annotation makes days annotated on all graphs in that dashboard:
changes(
    day_of_week()
    [1d:1d]
) > 0
