I wanted to Visualize two Prometheus Query in Grafana in one table as a raw list. the two queries have the same fields. the queries are
increase(message_recieved[$_range])andincrease(message_sent[$_range])
The table looks like this
**I tried to use merge transformation **
it visualized them in one raw and two extra columns “value A” and “value B”.
|namespace|pod|service|Value #A|Value #B|
|mkn|mkn_1875|jck|29|36| -
but I wanted it to be visualized in raws.
