latest -
Hi thanks for the lib! I wonder whether it is possible to have multiple sparklines in one grafana table? -
seems not possible? -
What happened?
n/a -
n/a -
n/a -
n/a -
n/a
I see: Just create two prometheus queries, and use one extra Merge transform
