I am using an api as simplejson datasource in grafana.When I am trying to see tag values in a panel by making multiple queries manally, I am able to see trends for diffrent tags in the same panel.But after mapping those tags as variable, when I am trying select multiple tags from drop down I am not getting any data in the panel.If I try repeatation of tags, then I am getting multiple panels for the tags.But I want multiple tags in a single panel using variables.
Related topics
Topic | Replies | Views | Activity | |
How to set up the custom tags for multi-value in Grafana? | 4 | 29543 | March 25, 2019 | |
Merge data of multiple panels in grafana | 4 | 6481 | August 17, 2022 | |
Display multiples panels in 1 single panel | 1 | 6740 | May 25, 2022 | |
Variables Multi-value not working with Graphite tags | 0 | 763 | April 16, 2020 | |
I want to execute the single metrics query for multiple variable values | 8 | 31268 | September 1, 2021 |
