The latest log can be viewed within 5 minutes, the log cannot be viewed within 5-30 minutes, and the log can also be viewed before 30 minutes.
A bit more information on your setup and configuration would be helpful.
auth_enabled: false
chunk_store_config:
chunk_cache_config:
background:
writeback_buffer: 100000
writeback_goroutines: 100
embedded_cache:
enabled: false
memcached:
batch_size: 2048
expiration: 72h
parallelism: 1000
memcached_client:
addresses: dnssrv+_memcached-client._tcp.prod-loki-loki-distributed-memcached-chunks.log.svc.cluster.local
consistent_hash: true
timeout: 500ms
max_look_back_period: 0s
write_dedupe_cache_config:
background:
memcached:
batch_size: 2048
expiration: 72h
parallelism: 1000
memcached_client:
addresses: dnssrv+_memcached-client._tcp.prod-loki-loki-distributed-memcached-index-writes.log.svc.cluster.local
timeout: 500ms
common:
compactor_address: http://prod-loki-loki-distributed-compactor:3100
compactor:
compaction_interval: 10m
retention_delete_delay: 2h
retention_delete_worker_count: 150
retention_enabled: true
shared_store: s3
shared_store_key_prefix: index/
working_directory: /data/loki/boltdb-shipper-compactor
distributor:
ring:
kvstore:
store: memberlist
frontend:
compress_responses: true
log_queries_longer_than: 30s
max_outstanding_per_tenant: 2048
scheduler_address: prod-loki-loki-distributed-query-scheduler:9095
tail_proxy_url: http://prod-loki-loki-distributed-querier:3100
frontend_worker:
parallelism: 100
ingester:
chunk_block_size: 524288
chunk_encoding: snappy
chunk_idle_period: 30m
chunk_retain_period: 10m
chunk_target_size: 4194304
concurrent_flushes: 64
flush_check_period: 15s
flush_op_timeout: 10m
lifecycler:
ring:
kvstore:
store: memberlist
replication_factor: 1
max_transfer_retries: 0
wal:
dir: /var/loki/wal
ingester_client:
grpc_client_config:
max_recv_msg_size: 2097152000
max_send_msg_size: 2097152000
remote_timeout: 1s
limits_config:
cardinality_limit: 200000
enforce_metric_name: false
ingestion_burst_size_mb: 65536
ingestion_rate_mb: 32768
max_cache_freshness_per_query: 10m
max_entries_limit_per_query: 1000000
max_global_streams_per_user: 100000
max_label_name_length: 10240
max_label_names_per_series: 300
max_label_value_length: 20480
max_query_lookback: 90d
max_query_parallelism: 500
per_stream_rate_limit: 2048MB
per_stream_rate_limit_burst: 4096MB
reject_old_samples: false
retention_period: 91d
split_queries_by_interval: 15m
memberlist:
join_members:
- prod-loki-loki-distributed-memberlist
querier:
max_concurrent: 50
query_ingesters_within: 2h
query_timeout: 60s
query_range:
align_queries_with_step: true
cache_results: true
max_retries: 5
results_cache:
cache:
background:
memcached:
batch_size: 2048
expiration: 72h
parallelism: 1000
memcached_client:
host: prod-loki-loki-distributed-memcached-frontend
service: memcached-client
timeout: 500ms
query_scheduler:
grpc_client_config:
max_outstanding_requests_per_tenant: 2048
ruler:
alertmanager_url: https://alertmanager.xx
external_url: https://alertmanager.xx
ring:
kvstore:
store: memberlist
rule_path: /tmp/loki/scratch
storage:
s3:
access_key_id: ----------
bucketnames: loki
endpoint: ----------
http_config:
idle_conn_timeout: 90s
insecure_skip_verify: true
response_header_timeout: 0s
insecure: true
region: us
s3forcepathstyle: false
secret_access_key: -------------
sse_encryption: false
type: s3
runtime_config:
file: /var/loki-distributed-runtime/runtime.yaml
schema_config:
configs:
index:
period: 24h
prefix: loki_index_
object_store: s3
schema: v11
store: boltdb-shipper
server:
grpc_server_max_concurrent_streams: 0
grpc_server_max_recv_msg_size: 2097152000
grpc_server_max_send_msg_size: 2097152000
http_listen_port: 3100
log_level: info
storage_config:
aws:
bucketnames: loki
endpoint: --------
http_config:
insecure: true
region: ------
boltdb_shipper:
active_index_directory: /var/loki/index
cache_location: /var/loki/cache
cache_ttl: 168h
index_gateway_client:
server_address: dns:///prod-loki-loki-distributed-index-gateway:9095
shared_store: s3
index_queries_cache_config:
background:
memcached:
batch_size: 2048
expiration: 72h
parallelism: 1000
memcached_client:
addresses: dnssrv+_memcached-client._tcp.prod-loki-loki-distributed-memcached-index-queries.log.svc.cluster.local
timeout: 500ms
table_manager:
retention_deletes_enabled: true
retention_period: 100d
Use helm deployed and memcache cluster
When the log volume is small, there is no problem. When the log volume of a single application reaches a certain level, it will reproduce stably.
Since you set
to2h
, I’d recommend settingingester.max_chunk_age
to2h
as well. -
How many ingesters are you running? Check the
/ring
endpoint of your ingesters and make sure all members are present. -
This is probably not related, but table manager is no longer needed if you enable compactor, so I’d recommend turning it off with:
table_manager:
retention_deletes_enabled: false
- Found ingester.max_chunk_age the default is 2h
- ingesters is all members are present.
- I don’t quite understand why the table history deletion management is closed. Isn’t compression only improving performance?
Will it have anything to do with chunk_retain_period: 10m
Can you post a screenshot of your
/ring
screenshot? -
Any interesting log from querier? Enabling debug log may be beneficial as well.
As mentioned, table manager is not necessary if compactor is running. See Retention | Grafana Loki documentation (again this is unrelated to your issue most likely, you don’t have to fix if you don’t want to).
Thanks,My problem has been solved,replication_factor set 1 ,Now I set 3,It is suspected that setting 1 may not be handled and will have an impact during query.
