Loki log expire time
Hello there!
I’ve configured whole PGL stack but didn’t think about one, very important thing which is - log expiration time.
I’m not able to view logs older that 24h i guess? I’d like them to be visible for at least 14 days, perferably 30 days.
Also, they should be stored in the filesystem, i don’t have any network storage for now.
Below is the configuration I use now (after some tweaks - I changed the times), will it work? I have to be 100% sure that the logs won’t disappear after 1 days and I’ll be able to view them.
auth_enabled: false
server:
  http_listen_port: 3100
  grpc_listen_port: 9096
  http_server_read_timeout: 20m
  http_server_write_timeout: 20m
ingester:
  wal:
    enabled: true
    dir: /tmp/wal
  lifecycler:
    address: 127.0.0.1
    ring:
      kvstore:
        store: inmemory
      replication_factor: 1
    final_sleep: 0s
  chunk_idle_period: 1h       # Any chunk not receiving new logs in this time will be flushed
  max_chunk_age: 1h           # All chunks will be flushed when they hit this age, default is 1h
  chunk_target_size: 1048576  # Loki will attempt to build chunks up to 1.5MB, flushing first if chunk_idle_period or max_chunk_age is reached first
  chunk_retain_period: 30s    # Must be greater than index read cache TTL if using an index cache (Default index read cache TTL is 5m)
  max_transfer_retries: 0     # Chunk transfers disabled
schema_config:
  configs:
      store: boltdb-shipper
      object_store: filesystem
      schema: v11
      index:
        prefix: index_
        period: 24h
storage_config:
  boltdb_shipper:
    active_index_directory: /tmp/loki/boltdb-shipper-active
    cache_location: /tmp/loki/boltdb-shipper-cache
    resync_interval: 60s
    shared_store: filesystem
    query_ready_num_days: 14
    cache_ttl: 336h
  filesystem:
    directory: /tmp/loki/chunks
querier:
  query_timeout: 20m
  engine:
    timeout: 20m
compactor:
  working_directory: /tmp/loki/boltdb-shipper-compactor
  retention_enabled: true
  compaction_interval: 10m
  retention_delete_delay: 336h
limits_config:
  reject_old_samples: false
  ingestion_rate_mb: 16
  ingestion_burst_size_mb: 32
  max_streams_per_user: 100000
  reject_old_samples_max_age: 744h
  retention_period: 744h
chunk_store_config:
  max_look_back_period: 744h
table_manager:
  retention_deletes_enabled: true
ruler:
  storage:
    type: local
    local:
      directory: /tmp/loki/rules
  rule_path: /tmp/loki/rules-temp
  alertmanager_url: http://localhost:9093
  ring:
    kvstore:
      store: inmemory
  enable_api: true
  search_pending_for: 20m
I’m kindly requesting your help, because I don’t know how to configure this on my own.
Thanks in advance!
