Loki messages not showing up for a minute
When I send messages to Loki, it takes 45 seconds to a minute until I can see them in Grafana or get them with a HTTP request. Does anyone know what could cause this delay? This is my config file:
auth_enabled: false
server:
http_listen_port: 3100
grpc_listen_port: 9096
ingester:
flush_check_period: 1s
chunk_idle_period: 10s
common:
instance_addr: 127.0.0.1
path_prefix: /tmp/loki
storage:
filesystem:
chunks_directory: /tmp/loki/chunks
rules_directory: /tmp/loki/rules
replication_factor: 1
ring:
kvstore:
store: inmemory
query_range:
results_cache:
cache:
embedded_cache:
enabled: true
max_size_mb: 100
schema_config:
configs:
store: boltdb-shipper
object_store: filesystem
schema: v11
index:
prefix: index_
period: 24h
limits_config:
max_query_parallelism: 32
max_query_length: 99999h
reject_old_samples: false
ruler:
alertmanager_url: http://localhost:9093
