I have 2 schema_configs, the first one is a local minio instance that was used now. But I like to migrate to amazon-s3 so I added a second storage that is used in some days.
But how do I make sure that the bucket connection is actually working now? There is nothing in the log that anything failed nor are there any files in the aws bucket.
Is there a way to check if that is working when the '- from: …" is triggered and the new storage_config is used?
auth_enabled: false
server:
http_listen_address: 0.0.0.0
http_listen_port: 3100
ingester:
lifecycler:
address: 127.0.0.1
ring:
kvstore:
store: consul
prefix: service/loki/collectors/
consul:
host: 172.17.0.1:8500
replication_factor: 1
final_sleep: 0s
wal:
dir: "/tmp/wal"
schema_config:
configs:
index:
period: 24h
prefix: index_
object_store: aws
schema: v13
store: tsdb
- from: "2024-12-15" # <---- A date in the future on wich the new db schema is used
index:
period: 24h
prefix: index_
object_store: amazon-s3
schema: v13
store: tsdb
compactor:
working_directory: /loki/compactor
delete_request_store: amazon-s3
retention_enabled: true
storage_config:
aws:
s3: https://${MINIO_ACCESS_KEY}:${MINIO_SECRET_KEY}@s3api.domain.com
s3forcepathstyle: true
bucketnames: loki
# New tsdb-shipper configuration
tsdb_shipper:
active_index_directory: /loki/tsdb-index
cache_location: /loki/tsdb-cache
named_stores:
aws:
amazon-s3:
region: eu-central-1
bucketnames: sfw-loki
s3forcepathstyle: false
access_key_id: ${AWS_S3_LOKI_ACCESS_KEY_ID}
secret_access_key: ${AWS_S3_LOKI_SECRET_ACCESS_KEY}
limits_config:
reject_old_samples: true
retention_period: 90d
max_query_lookback: 90d
ingestion_rate_mb: 20
ingestion_burst_size_mb: 30
per_stream_rate_limit: "5MB"
per_stream_rate_limit_burst: "20MB"
shard_streams:
enabled: true
query_scheduler:
# the TSDB index dispatches many more, but each individually smaller, requests.
# We increase the pending request queue sizes to compensate.
max_outstanding_requests_per_tenant: 32768
querier:
# Each `querier` component process runs a number of parallel workers to process queries simultaneously.
# You may want to adjust this up or down depending on your resource usage
# (more available cpu and memory can tolerate higher values and vice versa),
# but we find the most success running at around `16` with tsdb
max_concurrent: 16
