Hi
is there anyway to force the override of a variable when changing dashboards?
We have constant variables defined on our dashboards and are overriding them per dashboard.
When switching dashboards, the variable holds the value of the last selected dashboard.
In my opinion this makes the local definition of a constant variable somewhat absurd…
I would suggest adding something like an override localy checkbox, if this doesn’t exist in some way.
Thanks for any hint how to solve this.
