Overrides is clearing out all vars when I only want one Variable to be updated
I have 3 varables on my DashBoard.
GroupID
locations_id_array
locations_id_selected.
I also have a text pannel with this as the OUTPUT for debugging:
There are 3 pannels
PanA-Groups is a text pannel that has Fields:
  • GroupID
  • location_ids ( ann array )
There is a GroupID override that does:
http://hss-grafana-2a98e863sdsddggdffd06.elb.us-west-2.amazonaws.com/d/edjtj9ffx7nk0b/a010-locationsbygroups?orgId=1&var-location_ids_array=${__data.fields.locationIDs}
PanB-Locations_Array, table
has just one column which is populated from the Locations_ID arrray from master.
The Data field in PanB is: ${location_ids_array}
When a Row in the PANB table is clicked, var-location_ids_array=${__data.fields.locationIDs} is executed, and PanB displays array of LocationsID’s as desired.
I also Have a
DEBUG-VARS Text Panel that displays when PanA is clicked and I believe the Variables are set correctly:
var-GroupID=&var-location_ids_array=%5B%222c889d34-f42d-47d9-a32c-a5c760894a29%22,%22b946c91f-6404-4d37-b30d-0fd3bc7fd6fd%22%5D&var-location_id_selected=
So… all is working to this point. However…
PanB also has an Override:
http://hts-grafana-2a98e863dc7efd06.elb.us-west-2.amazonaws.com/d/edjtj9ffx7nk0b/a010-locationsbygroups?orgId=1&var-location_id_selected=${__data.fields.A}
When PanB row is clicked PanB goes blank and I get this as:
DEBUG-VARS
var-GroupID=&var-location_ids_array=&var-location_id_selected=b946c91f-6404-4d37-b30d-0fd3bc7fd6fd
Notice that variables: GroupID, Location_id_array and location_id_selected all equal the same thing… which is wrong. I want each var to preserve its previous value.
QUESTION:
How do I change PanB behavior so that only
var-location_id_selected=b946c91f-6404-4d37-b30d-0fd3bc7fd6fd is added to the Varables and none of the other vars are updated.
