version 12.1.1 on MacOS in firefox browser -
I want to update the value of variables once I refresh or reload the dashboard. For example: I have a variable called “Heute” which is calculating the linux timpestamp of today. I a doing calculation within panels with that variable.result is a Linux timestamp:
click the refresh button within Grafana or reload the browser session. -
What happened?
the variable does not update - instead I need to go to edit mode - go to variables - run the variable manually and go back to the dashboard. -
in prio versions the variables did update on refresh or reload -
no logs
