I am trying to create a dashboard where a single variable can pull values from multiple datasources. Right now, query variables can only use one datasource, which makes it difficult to:
Combine values from different datasources into one variable.
Filter panels across multiple datasources using a single variable.
Provide “Include All” behavior for combined results.
My setup includes multiple clusters, each with its own datasource, and I would like a variable (e.g., namespace) that aggregates values across them. Panels should still use the appropriate datasource based on cluster selection.
Practical case:
I currently have three variables: datasource, cluster, and namespace. I want to remove the datasource variable. I can convert cluster into a custom variable, but then the namespace variable would need to search across all data sources and query them based on the selected cluster value.
Grafana version: 12.1.1
Is there a supported method to achieve this, or a recommended workaround? If this is not currently possible, I would like to request this as a potential feature.
Thank you for your guidance.
