Concatenating dashboard variables
Hi all,
My apologies if this was already discussed (pretty sure it was) but i can’t find it (my searching skills are legendary in a horrible way)…
    Grafana 10.1.4 running on EKS
Trying to concatenate multiple variables on a dashboard so it’s easier to manage sources.
I have multiple sources for each customer.
Customer deployment A
  • Prometheus
  • Cloudwatch
  • Logging
Customer deployment B
  • Prometheus
  • Cloudwatch
  • Logging
Customer deployment C
Customer deployment D
Right now, i am adding the variables to the dashboard, but each time i want to change, i need to go 1 by 1 and change them.
Variable 1 - Customer X Prometheus
Variable 2 - Customer X CloudWatch
Variable 3 - Customer X Logging
Is there a way to create a variable that would change all at once?
  • Customer var
    – Change Prometheus
    – Change CloudWatch
    – Change Logs
So, the dashboard still refers to the datasource choice, but those are all changed at once by a single var?
Thanks in advance,
NF
Up :slight_smile:
Anyone has an idea on how to do this?
Up!
Still looking for a way to do this :frowning:
Anyone can weigh in on this? :slight_smile:
Ok, i was able to do it for anyone who is interested.
Step 1:
Define custom variable named “customer” with any label you want.
On this variable, the partial name of the datasources is defined as values separated by commas.
ie: CustomerA, CustomerB
Step 2:
Change the original queries with the following regex:
/$customer.ProductHere*/
How does it work?
Let’s imagine 2 datasource names:
Customer1-ProductHere-Cloudwatch
Customer2-ProductHere-Prometheus
When you define datasources, you define them as:
ProductHere_Cloudwatch
ProductHere_Prometheus
With the above solution, this will give you a single dropdown, aggregating the datasources.
Then, it’s just a matter of hiding the original datasources from the dashboard display and done.
You only show 1 drop down for both datasources.
