Azure managed Grafana - version 10.2.1 -
Needs to display all clusters from multiple Prometheus DataSource’s -
What happened?
Hi All, can some one please help on merging two variables. My env like we have 2 Prometheus Datasource’s configured. I have created one dashboard with two variables like $datasource and $cluster. In $datasource variable we can see all the configured Prometheus DataSources. Actually, one DataSource contains cluster1 and another contains cluster2. When I drop down $cluster variable it is showing only one based on $datasource selection.
My requirement is both clusters 1&2 should display in cluster variable. -
In $cluster variable should display both the clusters -
