I noticed that you have solved several doubts about the multiselect with a variable. I have three configured variables: the first one is STATION: SELECT station FROM alert_register, the second one is UNIT: SELECT station FROM alert_register, and the third one is active: SELECT active FROM alert_register WHERE station IN ($STATION) AND pumping_unit IN ($UNIT); each of the three variables feeds a panel of the VARIABLE plugin and is connected to the alert register panel as follows:
SELECT
ALERT_ID AS ALERT_ID,
ALERT_STATE AS ALERT_STATE,
COALESCE(REGISTRATION_DATE, '0001-01-01 00:00:00') + interval '1 hour' * 5 AS REGISTRATION_DATE,
COALESCE(TO_CHAR(REGISTRATION_DATE, 'YYYY-MM-DD HH24:MI:SS'), 'No date') AS DATE_AND_TIME_OF_REGISTRATION,
ALERT_TYPE AS ALERT_TYPE,
STATION AS STATION,
PUMPING_UNIT AS PUMPING_UNIT,
ACTIVE AS ACTIVE,
PRIORITY AS PRIORITY_LEVEL,
OBSERVATIONS AS OBSERVATIONS,
MAINTENANCE_NOTICE AS MAINTENANCE_NOTICE_NUMBER,
DECISION AS DECISION,
AFFECTED_COMPONENT AS AFFECTED_COMPONENT,
RESPONSIBLE AS RESPONSIBLE,
COALESCE(UPDATE_DATE, 'No date') AS UPDATE_DATE
FROM alert_register
WHERE STATION = $STATION AND PUMPING_UNIT = $UNIT AND ACTIVE = $ACTIVE
ORDER BY ALERT_STATE DESC;
When I select one result for STATION, one for UNIT, and one for ACTIVE, there is no problem, everything works perfectly. However, when I select more than one UNIT, more than one STATION, or more than one ACTIVE, the log panel, where I have the list of my alerts, gives me the following message: "db query error: pq: syntax error at or near “,”. Could you help me solve this problem, please?
