Multiple Graph multiple Queries , in One panel PostgreSQL data source
    i want to creat a panel with all Variable i defined.
Variable name = LH
SELECT DISTINCT"TE_ID" FROM public." Daten"
Preview of Values
all 1 2 3 4 5 6 7 8 9 10
Panel
SELECT “SOC” AS “value”, “Zeit” AS “time” FROM “Daten” WHERE"TE_ID"= $LH
  • What happened?
    if i select
    one Variable it Worke Properly
    more then one Variable : db query error: pq: syntax error at or near “,”
    All Variable: db query error: pq: syntax error at or near “,”
i’m expeding to be abble to see all Variable in one Panel,
10 diferent graph in one Panel with label 1 to 10.
SELECT “SOC” AS “value”, “Zeit” AS “time” FROM “TE_Daten_Allgemein” WHERE"TE_ID"= $LH
PostgreSQL data source | Grafana documentation
where TE_ID in (${LH});
as you cant have
WHERE TE_ID = 1,2,3,4,5,6,7,8,9,10
thank you very much the Solution
but is just showing the Overage value of all 10 Variable and
i want to be able to combine in one panel the result of all LH
LH= 1+2+3+4+5+6+7+8+9+10
SELECT “SOC” AS “value”, “Zeit” AS “time” FROM “TE_Daten_Allgemein” WHERE “TE_ID” in (${LH}) and $__timeFilter(“Zeit”)
Result have been limited to 1000000 beacause the SQL row limit has reached.
so i used the time Filter
oh sorry! :slight_smile:
here is how you would do it
just add new row then select the value you want to use to repeat paners. just leave the query like it was
Then select the gear
when you click that gear this shows up to help guide you to select the column to repeat panels on
thank you @yosiasz
is it possible to have something like This by selecting all Variable buy using just one Querry?
i did this one with Influx DB
you are very slippery. what is x axis value?
in my case
the X Axis ist the “SOC” and the Y Axis is the “time”.
and 10 LH.
you mean the other way around? X axis is time, Y is value?
sorry. yes exatly.
X axis is time, Y is value.
LH is the number of the Hause, that mean i have 10 Hause
wow i nerver thougth about that.
why does my column not automaticly recognise
I can neither select LH nor write manually.
Cause you are missing the metric column TE_ID in your query
