PostgresSQL query for multiple variables in a single panel
    Grafana OSS v9.0.3 on Linux
    I’m trying to build a panel in grafana using postgres connector and multiple variable select without having to go through pgplsql if possible
my variable is a list of uuids
I want to run a simple select * ${variable_id}.table_name where the uuid is the schema name.
Using a single variable selected, this works but once I select multiple it obviously breaks
Is there a way to loop over the selected variables, run the query above all in one single panel without using the repeat panel option? trying to do a ‘rollup’ view of sorts all in one panel
(e.g in pseudo code):
for var in ${variables}
  select * from var."table_name"
end
Welcome @ks2211
You have uuids as schema? Why such design?
Anyways try to use a stored procedure and do your logic in the spric would be my recommendation
Pass the var as command delimited or something like that
Hey @yosiasz thanks for the response.
Is it possible to loop over variables in grafana? Was trying to avoid the stored procedure if possible but if thats my only option, I’ll go that route
Yes you could loop but depends on what the final visualization you want to see
Please post the data from thr select query and how and what you to display
@yosiasz I’m trying to visualize a table.
id| variable_id | name
uuid1|variable_uuid1|test
uuid2|variable_uuid2|test2
uuid3|variable_uuid2|test3
uuid3|variable_uuid3|test4
all of the schemas have the same table structure so im trying to loop over the multiple selected variables, run the same query and combine all of the data into a single panel
so if I were to manually add queries, it would look something like
select * from variable_uuid1.table_a
select * from variable_uuid2.table_a
select * from variable_uuid3.table_a
etc
i was going to recommend using dynamic text plugin but seeing this schema design I would go with stored procedure.
